kevinomc1989
- Jun 25, 2011
- 26
Hi,
I am about to go bananas over this problem and I am hoping someone can put in some great input.
OMC Electric Shift 800
Chevy 350
Problem: After I bought my boat about a year ago I am just now getting it cranked and trying to tune it up. When I would crank it, it would start just fine and the choke seems to work correctly only it idle at 1500 rpms after it warmed up. I took the throttle cable off pulled the throttle lever down and it would idle around 1200 RPM's then die if I went any lower. I adjusted the idle mixture screws on the Rochester Quadrajet 4MV and was able to get it down to fluctuate around 750-900 RPM's. Manual says to idle around 600-650. If i pulled the throttle down that far it would just die. I figured I would start out with the most common and replaced the plugs (.035) and plug wires...No change. I just recently rebuilt the Quadrajet and the only change is now when I pull the throttle down as far as it will go it is at 800 RPM's and fluctuates +/- 50 inconsistently. I am assuming the idle mixture screws are just out too far and that's the only reason it isn't dieing when the throttle is down all the way. Also I mixed sea foam in the gas tank and have changed the oil twice to flush out all the moisture in the oil form sitting so long. Any input would be greatly appreciated. I thought that it might be the fuel pump but it runs fine if i rev it up to 4000 + RPM. So that rules that out. I know on some configurations there is a vacuum line that runs from the carb to the fuel pump but mine is capped off at the carb and there isn't a vacuum port on the fuel pump. Should there be?
Chevy 350
