I have a 115hp 1980 Johnson outboard. I have been trying to find a fault in the motor. I purchased a new powerpack. before I fitted this new pack the motor turned off and on ok with the key. After I fitted the new pack the key only seemed to shut down the side of the motor that was connected to the second older powerpack. I removed and replaced the new powerpack and then the motor turned off with the key just fine.
Can I fix this by changing the wiring?
I want this powerpack as a backup but it is no use to me if I cant turn off the motor when it is fitted.
Can anyone please tell me why this powerpack would not turn off with the key?
The numbers on the new pack seem to be the correct ones for the suggested replacment.
