1988 evinrude outboard 25hp
pmo1955
cant find shifter rod release to drop lower unit to replace water pump.HELP?:facepalm:
jbjennings
Re: 1988 evinrude outboard 25hp
Remove plastic water intake screens from lower unit. Unscrew both nuts on shift rod and slide out of the way. REMOVE the black plastic split washers from the shift shaft WITHOUT LOSING them. The rod will now slide out.
Have fun,JBJ
pmo1955
Have fun,JBJ[/Qt thanks for the info!happy fishing.
