Robert Hodges
- Jan 1, 2009
- 11
Dear gents, and ladies,
I have a 72 6hp that I recently rebuilt. No pryer experiance! This motor was frozen everywhere and with some luck and help I have gotten her to run again. The problem is it doesn't go to fast. I can go 1 mile in 5.5 min. I have a 4hp that does the same. I believe the bigger motor should be faster. The compression on the 4 is 120ish per cylinder. On the 6 it's around 85ish both cylinders. If its leaking air should'nt the gauge go down? New head gasket? Iput block on glass and it was flat but didn't check head cover.
