Timing on a 1979 - 228
osborne looney
DUMB QUESTION TINE vacuum line have to be be disconnected ? while timing so old i cant remember
thanks i boats
Re: Timing on a 1979 - 228
thanks i boats
Ayuh,.... You have an Automotive Distributer, 'n NOT a Marine distributer,....
Marine distributers Don't have a vacuum line....
What you've got, Won't work so well, 'n is a serious EXPLOSION Hazard...
achris
More fish than mountain goat
I'm with Bond-o... Get that AUTOMOTIVE distributor out of there.... And if the vacuum line connects to a fitting on the carb, it means that's automotive too.... Bad idea!
osborne looney
no it is a marine dist like i said i am old (lol) and away from it right now will be tinkering with it later thanks for the info
achris
If it's a marine dissy, there will be no vacuum advance line.... Just set the idle to about 650-700rpm and set the timing to 8?BTDC...
Chris........
