Re: bolting up lower unit to upper Mercruiser Alpha One
we're having a heck of a time getting the lower unit to bolt back up to the upper unit. What is the best/proper way to make sure this bolts up correctly with respect to input shaft and reverse gearing being synced up properly?
imho, the best way is to take the whole thing off. upper and lower. then put them together on the bench. it's almost easy to mate the two when on the bench. in contrast, imho again. putting the lower back on the upper with the upper still on the boat is a real challenge. been there done that. repetitively. most painful to do. line all that stuff up, keep it in fwd, etc.
also, be sure the water tube guide is in the lower (installed in the water pump housing), and the water tube in in the water pocket cover in the upper. use some lub on the ends to assist mating.
again. mating the upper to the lower on the bench is a one man job, might take from 1 to 3 tries before ya get it (+ ya can watch the parts mate as they go together). mating the lower to the upper w/ upper still on boat is a two man job at the least and may take many tries before success and you'll be worn out after dong the deed.
also. if ya remove the upper, there's pm you can do while the upper is off. ie. check alignment, lub coupler, check gimble brg. lub ujoints, check for water intrusion into the bellows.
