Re: questions on a evinrude outboard motor i was given
Look up the serial number and you may find out it is not that old but it has a home brew cover.
Once you establish the year I would suggest you order a manual.
I will move this to the correct forum section.
BTW that shift spot is where you would be idling low enough to safely shift
