fifty5iven
- Jun 1, 2012
- 2
I have a 1982 Evinrude boat motor, I have recently replaced the shift and throttle cable. It goes into Neutral and Forward, when I put it inot reverse it makes a loud rattling noise, in the cable and in the throttle. It does not engages into reverse, is this caused by the shifter rode or the shifter cable? I put the same length cable and adjusted it the same way it came off the motor. When the motor is not running, the prop goes into neutral, when throttle is in neutral. When throttle is put into forward and reverse,the prop moves 3/4 of an inch left ot right. what can I do, to fix this problem?
