Yamaha Trim Gauge off
MnToyGuy
I just bought a 2000 Lund Pro V with a Yamaha 150 OX66 EFI. The motor moves fine throughout the range, but when it is all the way down, it reads 3/4 trim and moves up from there. Any ideas what I should be looking for?
connemaraisland
Re: Yamaha Trim Gauge off
There is a small plastic tab on the pivot shaft of the motor when it tilts forward. It contact a variable resistor when the motor trims up, loosen the scrw and adjust it to where you want it.
MnToyGuy
Thanks for the info, got it fixed. It was broken. The original piece is plastic, but the replacement part is metal. I appreciate the help!
RWC Whaler
Do you know the part number? I have a F90 and mine is broken too. It is plastic and I would loke to mail order a replacement. I have a maintenance repair manual, but didn't find the part number. Thanks
Don S
Welcome to iboat RWC, best to start a new thread of your own (as that red warning bar you ignored suggested) you don't have the same part.
RWC Whaler
Don, I'm new to the iboat forums and don't recall seeing a red bar. I thought there was a reasonable relationship between my issue and Mn Toy Guy's part, but I trust your input. Thanks
