Re: Replacing the piston on a 125 HP
Without writing a book, let me give you a little build up to the climax. When I bought the boat from my uncle, only one of two 125's were running, I did alot of diagnosis and was able to get the stbd engine running after replacing the CD modules.
In doing my diagnosis, I saw that my # 2 cylinder compression was at best 85 psi compared to 125 and 135 and 125 in the other 3. I thought I might have blown a head gasket through the water jacket since I was seeing what I thought was alot of steam in my exhaust. I replaced it, and ran it till last September, about 6 times for about 4 hours tops. Then I moved to VA, and she wouldn't start again. After a ruined fishing trip, I decided to tear them both down and rebuild them both. That's when I discovered that the top ring on #2 had broken inside the cylinder and about a 1.5 inch segment was gone. I did discover that something had bounced around in the top of the cylinder as there were impacts in the piston crown all over. There were no particles in the chamber when I replaced the head gasket the year before and the same was true when I disassembled the power head last week. And the bottom ring had been unable to expand due to having been locked into the second groove by the broken fragment, so it was likely contributing to not maintaining the pressure.
So my logic is after having measured out the bore in 8 locations in each cylinder, number 2 did have some bad spots. I'll show you pictures.
My plan was to hone out the cylinders and replace all the rings and #2 piston and rings and try to get by.:facepalm:
I'll have the boat repair facility do that for me but if I was close enough, I'd drive over to see ya. I appreciate the offer.
