So I have a torn shift cable bellows that needs replacing. While I was messing with the drive to replace ALL of the bellows I thought I would do the impeller as well. Now because I such a smart fellow I decided to remove the lower half to access the impeller and just leave it off while pulling the upper (to replace the bellows) to save some weight on my back. So I have removed the lower half, the trim actuators and all 6 nuts on the upper. The gear shift lever is all the way fwd at the helm. As I understand things it should just slide off at this point but it won?t. The drive will come out about 1/8" but no more. I also tried with the gear shift lever in neutral and reverse with no luck. I have tried to gently pry as well with no luck.
So here is my question. Do I have to have the lower half attached to remove the upper half? If not what am I missing here?
1995 Sea Ray
5.0 Mercruiser
Alpha One gen II out drive
Thanks for any help,
Chris
1995 Sea Ray
5.0 Mercruiser
Chris
