I am new to this site and not sure if this is the proper area to list this problem.
I have a 90 Sea Ray 230CC and I am having some major issues with it listing mostly to the port side. I have tried to use my power trim to help adjust this problem with very little success. There isn't any issue of the boat being overloaded on the left or right for that matter. I have removed the trim fin from my outdrive to see if that was causing the issue and still nothing has improved.
This past weekend I had a neighbor hold the outdrive while I was in the water and he was able to move it slightly left to right with not movement at the steering wheel. I then had him hold the outdrive and I move the steering wheel and had about 1.5-2 inch in both directions with no noticable movement in the outdrive.
I know believe my issue is the steering, I have also noticed that while driving straight the boat will turn to the port side from time to time. This happens usually when I am at higher speeds.
Is there anything that I can do to help tighten the steering up and maybe fix the list.
Thank you for any and all help.
Eric
Eric
