I thought it was a bad shock absorber but so I removed a washer and it seemed to do the trick. I ran it for about 40 minutes then it sounded like it was going to lock up.... When I remove the lower unit and reinstall its good for a little bit but then the same thing.... When it happens it feels like it has a ton of compression but I release the lower unit its fine again???
