Hello, I am new to the forum and am having a few issues with an 1989 Johnson 70hp VRO. I have rebuilt the powerhead as well as the carbs and disconnected the VRO. The problem I am having is that when the engine is running it is spitting fuel out of the throat of the carb as well as when the primer is primed and the motor is tipped. The motor runs very well at all rpm ranges but something is wrong as I am burning a ton of fuel and making a mess of the splash well of the boat. I now have the carbs off again checking float levels but cannot find anything wrong there, and the needle /seats are new as well as clean. Anyone have any ideas? I am setting the float level with the body with the carb upside down and the gasket installed. I am setting the drop at 3/4 of an inch from the body to the part of the float closest to the body, if you follow me there. This is happening on all three of the carbs...any help is appreciated.
