Ok any help will be great! Here is the problem. I have a 1996 mercruiser 454 mpi mag that will only start if you spray fuel in the plenum. I have a new tps sensor, new fuel filter, cap and rotor, compression is 150 in every cylinder. Also new mechanical lift pump. I have not scanned for codes because I have no scan tool and there is not one locally. Once you spray gas in the plenum it fires right up and runs but runs rich and dies out if the idle drops 1200rpm. Not sure whats going on??? Any help will be great!
Thanks
Thanks
