Re: Question about wiring a depth finder.
In a properly wired boat, the fuse block is wired directly to a battery. Ignition switches can't handle the amount of current all the accessories can draw. The ignition switch, which is powered separately through the motor's electrical system, generally only powers the gauges plus the starter solenoid. And the ignition, if the motor doesn't have a magneto.
