I have a 1978 evinrude 115 hp, how can I if its equiped with Speed Limiting Overheat Warning system (S.L.O.W).
I recently had it out in the bay and the heat gauge showed about 230f it looked to be pumping good at 4000 rpm but was pumping weak at idle, I had a new impeller put in it and just putting around at 1000rpm in a no wake zone the temp gauge showed a bit over 180. my motor does not have a ovwerheat alarm so I am concerned I amy have other issues as I am not sure of the correct opertaing temps..
Thanks
Thanks
