2002 150HP Mercury XR6 cooling issue
Tell-tale stream not very strong when idling. Sometimes kind of sputtering, sometimes steady stream.
Water PSI gauge very erratic. Jumps around from 5 to 15
Alarm from throttle/shift control beeps after running at 2500RPM for a few minutes.(assume it is overheating alarm)
Installed new water pump impeller. No change.
2002 150HP Mercury XR6 s/n OT148198
Re: 2002 150HP Mercury XR6 cooling issue
Any suggestions on what to check or try next would be appreciated.
Express 150HP Mecury XR6;3794757]Tell-tale stream not very strong when idling. Sometimes kind of sputtering, sometimes steady stream.
westexasrepublic
check thermostats opening properly, then check poppet valve. both may just need replacing. cheap and easy. youtube the videos
