I have a 2001 Cruisers 3470 with twin 8.1s mercruisers. I did some routine maintenance(changed impellers) and now the starboard engine will not start. It doesn't have any spark coming out of the coil packs. I've swithced all the fuses, relays, crank position sensor and camshaft sensor but it still will not start. I've checked all the wiring harnesses they all seem tight and I don't see any broken wires. I can't find this problem occuring to anyone else when I search the forums. I had a marine mechanic plug in the quicksilver computer as well as a laptop and they can't seem to find any codes that shouldn't be there and told me there wasn't anything else they could do at that time. I assume I'll have to take it to a mechanic for thourough troubleshooting but was hoping somebody had a tip on what I could have done, or if it is completely unrelated to the impeller change.
Over the past few weeks when the RPM went above 3500 rpm on the starboard engine the engine alarm went off but as soon as I slowed down it went off, again not sure if it's all related.
any help would be appreciated.
thanks!
thanks!
