Ok guys here we go again! Had my 89 Cobalt this weekend and was a disaster! First dipped in the water wouldnt even turn over just clicked. Tapped on starter and it slowly turned over. Changed battery with battery out of suv. Started fine then throttled down ran great for about 5 min then just died. Got it started and it ran but at 10 mph wot. It acted like it was starving for fuel, however, before we took it out I installed a new 19p prop hydrofoil and new water/fuel separator(10micron) filled up with gas with the 10% ethanol which I have always done. The last time we had it out it started dying on me but would restart and run fine thus made me think to change water separator.
So i took the line off the carb to make sure it didnt have a filter and just a screen which it did just have a screen. Took off water separator and was filled with fuel like overflowing when i unscrewed it ( which is may be normal)
Please give me all the help you can. I am trying not to take it to the dealer and get my head ripped off.
OH and it never ran hot.
I am not sure if i have a fuel problem or ignition problem or something completely different.
These are the things ive heard:
Bad ignition coil
using gas with ethanol
Thanks in advance for ALL your help.
Toby
1989 Cobalt 19BR 5.7 Mercruiser/Alpha one
Bad ignition coil
Toby
