Re: Bondo 3M products
Wow, ummmm. You can absolutely use those 3m products to do your transom.
The resin is waxed yes, this is in no way the kiss of death. It's put there for a reason, to harden the resin on the surface. Yes it is more work if you use it to laminate (sanding and cleaning with acetone), no it won't fail if you clean it. That is a completely wrong statement to say it will. This is just work you don't need to do.
You could buy some unwaxed and keep the waxed for your last layers. It's there for a reason and works great.
You don't want to use west system epoxy unless you commit to use epoxy, poly won't stick to it.
3m cloth and mat work fine, your over paying and the folds to stick them in the little packs are a pain. Use your mat between your ply pieces while laminating them, wrap it around your edges when sealing your laminated transom piece and up against the outer skin.
Definitely check out some 1708. It's mat stitched to cloth and is way easier to work with, plus it's stronger. I'd use it to build your new inner skin and to tab the transom in. Tabbing with mat doesn't do much of anything.
(wow woodonglass what's with the attitude? It's a little over the top don't you think? It's bad enough your NOT correct!)
