90hp Johnson 98 cuts out
silverfox71
Hello everyone, I am needing some help with a problem that started on my boat motor last year. It was full throttle that the motor would cut out at for a split second. This year it is getting worse. It is doing it at lower RPMS as well and it is cutting in for slightly longer times. The motor never completely dies it just cuts out. I have tried to pump the bubble up to see if it was fuel.....not that it sounded like it was, but that didn't make any differency to when it would do it. does anyone have in info that was help? I will be at the lake today and then I need to go home. I won't be able to try anything after today. Thanks
