Help, will not go into reverse.
cooked
The outdrive will shift into forward, but not into reverse. Boat is set up on electric toggle switch. I've changed the switch and the 2 solenoids. I am getting proper current to each item but it still will not go into reverse. Can anyone help? OMC outdrive with GMC 350 engine. 1976 Stardust cruiser.
southkogs
Re: Help, will not go into reverse.
Have you checked OHMs? I wonder if the coil for reverse isn't working? Maybe a short?
Howard Sterndrive
omc never used solenoids for shifting, so it sounds like you are working on someone's backyard creation.
you can look for a factory shifter (either pushbutton or lever) or use a drum switch. The coils carry about 5A so a heavy duty drum switch designed for reversing motors will work fine without any relays or solenoids.
