Rayzor
- May 5, 2007
- 172
I followed this article "http://www.duckworksmagazine.com/05/columns/max/5/index.cfm" to the letter to convert a new to me 1957 18 to a fuel pump. So I took the boat out with it for the first time. Mind you it ran great in a barrel for an hour prior to this. I left the ramp and took off for about a mile all the while running great at wide open. Then it just fell on its face and died. I checked all connections for leaks and all was tight. The glass filter bowl remained full. I can get the motor to run and stay wide open as long as I pump the primer bulb. I pulled the fuel feed line to the carb while it was running and the pump was squirting, just not alot of psi. at idle. Any thoughts? Could a sticky needle valve in the carb be causing this? Help!! Also the mikuni pump part#DF44-211-D flows 14 liters per hr. if that helps
