Hi everyone, I just bought a monark bass boat with a 1985 evinrude 90 horse. I took it out the first time and ran a 6 gallon tank of 50:1 mixture and it ran great minus a couple stalls after running it hard and trying to idle, next day I took it out and ran fine for a while then it lost power and would barely plane out. On land it seems to run fine but when I put it in the water it does not have full power under a load. I looked at the plugs and they looked a little oily so I cleaned and wire brushed them until they looked like new. same problem after that. I took the carbs apart and they were spotless so I cleaned them anyway and put them back on. I also tested spark and compression on all cylinders. good spark and 125 to 135 psi on compression. I noticed a couple of fuse blocks on the top rear of the motor and a couple electronic components that I have no idea what they are or if they could be causing the problem. I appreciate any help or points in the right direction! Thanks.
Tom
Tom
