I have a 1994 115 evinrude. At about 3200 rpm a constant alarm sounds. From what i read it sounds like over heat. Hav repair shop install new water pump and still no change. Everything seems to run fine even when alarm sounds but don't want to hurt engine. If I thrittle back just below 3200 it goes away, but anything over that it sounds. It happens at any time while running from right out off the dock to after i've been on the water for a while. Any thoughts? Thank you.
