I purchased this boat recently and it has been making this distinct sound. I made a video of it so you can listen at this Utube link.
http://www.youtube.com/watch?v=fD-xSG3jfvw&feature=youtu.be
I have been reading the forums and read a lot about the valve lash adjustments. I just finished doing those and the engine sounds the same. The motor is the 3.0 GM, 1992. It runs great at all RPM and the boat only has about 50 hours on it. It is like new. I have listened with a pipe and a hose and can't seen to narrow down where that noise is coming from. At idle it resembles a diesel. I also removed the plug wires one at a time with it running. No change in the sound as I have heard that if the sound gets quieter that would indicate pehaps a bad bearing or crank bearing. I have read on some posts that this could be the fuel pump. I am going to pull the fuel pump but was wondering if there was something to look for when I got it out that would clue me in that it is what in the fuel pump is making the noise.
Any advice would be appreciated.
Ed
Ed
