I recently installed a rebuilt engine (Ford 302)and when aligning the engine, had to drop the front down all the way on the mounts (took the nut off and put a thick washer in there) and still has to go down more. Raised the engine, lowered the mounts a half inch (Routed out and epoxy) and still needed to go down more. Engine is sitting on the rear mounts good. Why is there a difference between the engine (Block). I used all the original brackets, mounts, bolts and it appears that this rebuilt engine will need to be atleast 1 and a half inch to 2 inches lower than the original. Are the blocks different? The front of the coupler aligns with the gimbal bearing nicely. I still have about a 16th inch to drop and it should be ok, buy I had to drop the front of the engine so much, my alternator and oil filter are almost hitting the floor.
