A few weeks ago I found a 1968 Holiday-V 18 foot with a 120 Mercruiser I/O. When I visited the previous owner to try and make a deal he bumped it over by pouring some gas down the carb and for me that was enough to take a little chance on it. It had been stored since 1996. The overall shape is about a 6 on a 1-10 scale.
Next spring or this fall it is definitely going to get re-decked due to a few soft spots. It could use paint because of the "touh-ups" the P/O did to the paint job but I can live with ugly paint. I'd rather enjoy the spray of the lake at W.O.T. while people point and laugh and say "look at that ugly boat go!"
So when I was looking at it the P/O was proud to show me that he had replaced the cap, rotor, points, condenser, and coil. Nice except for the fact that they were A, automotive grade and B the plug and coil wires (original Kiekhafer) didn't seat fully into the contacts of the cap. I didn't say anything about using automotive grade or worse yet mixing auto and marine. No reason to hurt his feelings and the price of $475.00 was firm anyway.
A couple of weeks ago I tried to get he started as is. I poured some fuel down the carb and dropped the cut fuel line into a gas can. I know it isn't the safest way but I was trying to start it, not trying to go boating. No dice. Cranked well and bumped a couple times but no starting.
Last night I went on Napa auto parts site and reserved a cap, rotor, wires, points, condenser. All marine grade but at NAPA prices. $45.00 later I have a running Merc 120.
I do intend to switch over to the electronic ignition instead of the points but for now I wanted to make sure she ran before laying out $120.00 for the kit plus whatever the higher power coil will set me back. I also want to covert to an internally regulated alternator but that will likely wait until I need to replace the existing alternator. At idle I was showing +25 amps on the guage. When I saw the water temp climb near the edge of red I figured the impeller was shot. When I looked back at the guage and saw it had dropped back to the middle of the green I was pleasantly surprised. The t-stat must have opened and water must've been flowing. I'm still going to put a new impeller into her and a new t-stat. I'm one of those not going to push my luck kind of guys over less then $50.00 worth of parts. I have the impeller kit and I'll order the T-stat and alternator belt when I order the transom re-seal kit from iboats.
So as far as maintenance items I'm already going to replace the bellows, lower shift cable, gimbal bearing, impeller,T-stat, and carb kit. I'll inspect the u-joints when I have the drive off. Should I be taking apart the manifold and replacing the gaskets as well or should I leave well enough alone if there don't seem to be any issues in that area? What else should I be looking to replace outside of what I have listed?
With a little money and a little work she should be in the water on Independance day. My master mechanic buddy is going to rebuild the carb for me.
