Eyecatcher222
- May 27, 2012
- 6
I am having a problem with my motor stalling out at full throttle. The boat starts great and runs for a few minutes at full throttle then it just stalls. Pulling back on the throttle allows it to idle fine and then I can't get it back up to full throttle again. I have checked and replaced the VRO pump and puls limiter, the fuel filter, the anti siphon valve, and the bulb. It seemed like it was starving for gas. I havent checked the fuel pick up as I am not sure how. Do I have to pull the sending unit from the top of the built in tank? Plugs look fine but it has the original wires. Could wires cause this type of problem. Any other thoughts. Any help is appreciated.
Thanks,
Joel
Thanks,
Joel
