ADK_Boater
- Jun 29, 2010
- 217
Hey Everybody,
I have a '72 Johnson 85hp that I had the starter rebuilt on last year.
I accidentally burned it out cranking it over for too long with not enough cool down in between cranks.
Anyway, with the spark plugs out it cranks easily, and steadily, and sprays a mist of premix out the cylinders.
When I put the plugs back, the pinion gear jumps up intermittently and engages for no more than a few seconds at a time.
Needless to say I can't start the engine.
After I ruined the starter it behaved as described as above.
After the rebuild it behaved as described above.
Before I burned it out, it behaved normally.
So, does anybody know what did they most likely not do right when I had them rebuild it?
How can I tell what needs to be fixed?
Should I just order a new aftermarket starter? ($95)
Thanks!
P.S. Starter solenoid is new.
Thanks!
