running great then grinding out of gear??
tforston6077
today i was up on plane in my 1978 formula 255, doing a test run on my new boat, i was doing about 4500 rpms and everything was fine, then the first wave a hit (not big) spun my rpms up as if i hit an air pocket so i pulled it back to neutral and a grinding noise occurs, sounds like its coming from behind the engine or so, even in neutral it makes the grinding noise, so i got towed in and havent touched it, could this be a linkage adjustment or clutch dog maybe? thanks in advance for the help im a newbie
rickryder
Re: running great then grinding out of gear??
Only way to know for sure is to pull the drive and start checking..... Have you checked the oil level in the drive?...... I had the same noise and found it to be the gears in the upper unit fried.... Good Luck!
tforston6077
Thanks I did check oil no shavings oil is full, I don't really have time to do this job might take it to a mechanic but can never trust some of them. Hopefully not to expensive
Ayuh,.... My Guess is, ya wore the splines out in the coupler, from a lack of Grease, 'n/ or bad alignment....
