Thank you for the help on my 40hp, I found a bad gas line and now runs good. And now my other motor the 77 140 wont start. Last summer I rebuilt the carbs, and replace the plastic ring under the fly wheel and has run like new since. Yesterday after I got the small motor running I started the 140 and was letting it warm up when it died and would not start again. Took out the plugs and they were wet so I put in brand new ones again and still would not start. I pulled a plug and grounded it and cranked the motor and saw spark but looked weak. I cked wires and connections and all look good. I have replaced the power pack 2 times in the past. Can I test the power pack? I have looked at past threads and found nothing about the power pack. Am I looking in the right direction?
