Hi, it's that time of the year when I am preparing my Searay 185 to go to her summer mooring but noticed a little problem. The petrol tank sender unit is situated on top of the tank which is just under the deck in front of the engine, accessible via a sealed circular screw threaded plastic plate. However, when I went to change the sender unit as the gauge is not working I have noticed a reasonable amount of water on top of the tank covering the sender unit and it's connections. Rust has appeared on the metal of the sender unit and I assume that water should not get to that location. Can anyone advise if this has happened to them, where the water can be coming from and suggest any remedies
