Hi All,
I just bought an old boat with a motor that looks to be in realy good shape except that the crank shaft will only turn a very small amount before "sticking" in both derections (it gets about 1/8" of piston travel).
The motor is a 1961 Evenrude 40Hp (Big Twin) M/N: 35022
Prev owner said that eingine used to run but got water in lower cylinder somehow. He said that he put diesel fuel in cylinder once he discovered water.
After getting it all home and making a closer inspection the motro still looks really good. I can find no discolored paint on the head or block, so hopefully not overheated. Lower spark plug looked good, no rust or discoloration.
It seems a sheme to not try to save this motor becoming a parts donor but need to figure out how it got water in the lower cylinder.
I did a search on this forum and did not find any threads, although I know that there has to be something about problem this out there already.
Can anybody offer any help with this or point me to some threads that have already discussed this?
What is/are the most likely causes of water in the lower cyl on the motors, and how are they best addressed?
I appreciate the help.
marty
marty
