stutterin_nate
- May 25, 2012
- 1
Hello
Here is my problem. When i try to start it i get a click and as i keep trying it will just start to turn over then nothing. As in nothing i mean no click when i try to start it. At the key i have 0 amps with the key at the on position the fuel guage goes to full and the tach pegs out. when i remove the positive or ground cables at the battery and put them back on i can start the whole process over again. I am leaning towards the starter has a problem. I bought the starter new last year and had no problems with it...
To get it to "try" to start takes a few turns. if i jump the slave it does the 1/2 a secound "try" to start instantly
The battery has been tested and is fine.
When i stored it last year everything worked fine. i just pulled it out of storage with this problem.
this is a 1994 mariah barchetta z192 with 4.3LX
Thanks !
Thanks !
