trim stopped working???? trim motor still runs
zefird
Hi guy i have a 1980 doggett trophy it has a 1982 evinrude 115 on it. I trimed it up the other day while banking the boat when i got back it the motor would not trim up or down. trim motor still makes noise when you hit the button. the trim motor also revs a little faster as if it has no load (could it just be the fluid?) but once agian the motor was stuck at almost full trim? any ideas????
boobie
Re: trim stopped working???? trim motor still runs
Check your fluid level first. As a wild guess, if the mtr runs faster than it did, the coupler may have broken between the mtr and the oil pump in it.
zefird
Thanks thats what it was i have it working now and back on the water!!!
