executech aviation
- May 24, 2012
- 2
I have a 1995 Robalo 2440 with twin 150hp mercurys carbed (OG423303 and OG429567). engines have good compression. I rebuilt the fuel pumps on both. replaced plugs, fuel lines, inline filters, water seperators. the engines idle pretty well, a little smokey (classic 2 stroke). when advancing the throttle to get on plane, one motor reaches 4500 the left motor only goes to 1800-2000rpm. the boat just kinda sleds through the water. you can hear the left motor surge 200-300 rpm up and down, knowing that its not real good for the engine to run at this rpm range, I come off the power. after a few attempts at this, the left motor will finally start picking up rpm and like a super charger came on, the motor finally roars into power. I use the boat for trolling so, i use it as is. I should sure like to have the instant power available to get through some of the inlets and not require 2 hrs to get back from blue water. anyone have any ideas on what is plaguing this engine. all help would be greatly appreciated. Thanks
