1975 225/888 I notice that when I am shifting into or out of gear, the cut out switch assembly does not move. The pivot bolt on the assembly is free to move by hand and is well lubricated. There is a new shift cable and everything else works fine. Seems like there is a little to much clunk when going into gear. That switch is suppose to cut the engine off momentarily while it is shifting in and out of gear right? Any suggestions on what to look for or how to fix/adjust it?
