So toward the end of last season i noticed a small drop of water coming out of the bottom of the impeller. I thought that changing out the impeller with the new gasket would fix it. Well it didn't and upon further investigation i discovered that its in fact coming out of the impeller behind the gasket surface.
I'm going to try and explain the location here so bare with me. The surface that the rubber part of the pump's housing mates up to has 4 like vented holes like behind the back surface of the impeller housing. its i guess the other side of the shaft that turns the impeller. The top vent appears dry and it wouldn't be a big deal if it didn't drip onto the pulley and sling water everywhere.
My guess is that its leaking around the shaft and thru the housing out the back? how do i fix this?
