Where to get a new 2 barrel carb for a 3.0 Volvo?
ss9940
Hi all!<br /><br />I think i'm buying a new carb for a 3.0 Volvo. Do any of you experts out there know where to get it cheapest? Dougrussell increased its price for about $150 - now costs over $500... I'm coming from Europe, so any help would be greatly appreciated. I tried on Ebay, but there are only rochesters & mercruiser carbs on there.<br /><br />Thanx,<br /><br />Alex
DHPMARINE
Re: Where to get a new 2 barrel carb for a 3.0 Volvo?
Marine carbs are not cheap.Why do you want a new one ?<br /><br />DHP
ss9940
Black exhaust, black soothed plugs - i think i'll solve it if i just buy a new carb
Don S
It may very well be a bad choke coil, not a bad carb. $50 instead of $500.<br />After the engine is warmed up, check and see if the choke is open.<br />Could also be a bad needle and seat, or float, or even a float setting causing it to flood. Lots of things to check before buying a new carb.<br />What year is it?
ss9940
It's a 1994... The choke is ok, it opens when the engine is warm - i checked it. My mechanic rebuilt the carb completely before first use (i bought the boat a year ago). Didn't change the float though; everything else was changed (i bought the holley rebuild kit on dougrussell). How to check the float?
searay3
Carb has to be disassembled (top off). If your not familiar with the internals of a carb, have your mech friend take it apart. The float can be checked by simply dropping it in a small bowl of gas. If it floats...it's good. If it sinks...even a little, replace it. There is a tool that comes with the rebuild kit with instructions for the setting.
Laddies
Banned
The float must be weighed to see if it has absorbed fuel, if it needs replaceing replace with a alcohol resistant float
jimmbo
Volvo uses a Holley 2 bbl on its 3 litre models. Holley uses a hollow brass float. You can shake it and listen for trapped fuel. <br />Alex. When your mechanic rebuilt the carb he might have set the float too high or installed the float damper sring(s) (used on some holleys) incorrectly
