85 mercury 90hp - overheating??/
kevinsstkd
I have a 85 mercury 90hp and after idling in water for about 5 minutes, the motor shuts off and you can see hot smokey air coming from carbs and vents. just had carbs rebuilt and it idles smoothly.
Chris1956
Re: 85 mercury 90hp - overheating??/
Kevin, That motor should run dead cold at idle. When was the last time the waterpump was replaced?
BTW - the motor may have an overheat horn, but will not shut off even if it overheats.
