Re: engine proformance question
unless that's a typo, a non-firing cylinder (caused by a grounded sparkplug wire) will contribute to gas in the oil. The cylinder isn't firing and is sucking in and expelling raw fuel, it will wash down the cylinder and get past the rings and into the crankcase.<br /><br />Dropping a cylinder on a big v-8 at no load and not at real low rpms, say > 800, can be not that noticeable so it probably isn't and should not be the cause of a 10" vacuum reading.<br /><br />First check the obvious, then figure out if the cam was degreed properly. That can be a cause of poor vacuum reading and may even require carb adjustment to maintain idle. Depending on the integreity of your mechanic that info, or mistake as it may be, can be covered up if you just ask him to check it during the teardown. But in answer to your question, yes camshafts (hot cams) which are designed for power at high rpm, typically have poor vacuum at idle and require more air at idle by either adjusting the idle set screw to open the throttle blades more, or by drilling holes in the throttle blades.<br />I don't have specific knowledge as to what cam specs and cam timing give what idle performance and expected vacuum readings, a google or visit a camshaft website would give you the best idea.
