I have a 1976 Johnson 85HP that is giving me fits.
I have between 98 and 105 compression on all 4 cyls, new plugs, new carb rebuild, and all new fuel lines. It starts fine on muffs, and everything works perfectly. I can put it into gear, run it up to a slow run and 0 problems.
When I put it into the water, it runs great, I can put it into gear and it still runs good (better sounding then on muffs) and it will go to a fast idle with no problems at all. Then I get to the end of the no-wake zone and try to open it up. Now it does fine on muffs, but as soon as I push the throttle past fast idle, it just dies. I'll start back, but it just quits like the key was turned off or something.
I rechecked my coils and they were fine, timing level is free and moving properly (I did notice that it dies after the end of the timing lever travel when the throttle moves past the max advance) and I can't find a single thing wrong with it.
Any idears?
Any idears?
