just to remind all you people out thee that own omc outdrives do not take out any screws on the port side of the outdrive to change lower unit oil.......there are2 screws on the starbord side of the outdrive plus one on top the middle one is where you put your oil in. if you take off the big screw on the port side a plate on the inside will fall down into the unit. it could cost some bucks to drop the unit and have it fixed.
moons
moons
