littlelakeden
- May 2, 2010
- 28
Hi everyone.I have a cooling issue.I wrote in before about my 1975 johnson 9.9 not puming water when you open up the throttle.I just put a tell tale in the top cylinder and it pumps the water out perfectly but it still dosen? come out the exhaust when you are at wide open throttle.The cylinder head is really hot.I can only touch the head or t stat cover for a couple seconds.The water coming out of the tell tale is fairly warm and when you are wide open the motor starts to miss until you back the throttle off.Is it possible that the thermostat is screwed.I just bought the motor a few weeks.Any info would be greatly appreciated.
