Took my Opti to dealer for coil change per service bulletin and they had to hook up computer for hours. Tech gave me a printout and kind of explained what to be concerned about. Tech printout was as follows:
Freq Counter -3609
Engine Run Time -295.56
Engine State -Run
Battery-14.14
Baro Pressure-28.29Manifold Pressure-25.69
Available Power- 100
Load- 5.1
MPR requests-32
That's the gist of it. He said my Thermostat may be stuck open or the poppit valve may be malfunctioning. That water may be flowing thru the engine all the time. Question is, since I'm a fisherman, the engine seldom gets to operating temp cuz I start and then go a hundred yards and then repeat. Would this be the reason for the error. I pulled the stat and the poppit and all was OK. Stat opens at 140 degrees/ Any feedback?
Thanx JIm
Freq Counter -3609
Engine State -Run
Battery-14.14
Load- 5.1
MPR requests-32
Thanx JIm
