Doesitfloat
- May 21, 2012
- 1
I went through a few threads and I might be close to the answer.
I have a 1975 Johnson 25EL75B
Prop turns and has thrust at idle, under load the prop is spinning but low thrust.
With the propellor off I can torque the bearing pin ( by hand) and move the bearing 3-5 degrees. Then it returns.
With the motor running and no prop, the unit shifts into both fwd and rev. While running at med throttle removing each of the spark plug wires resulted in lower RPM.
I think it is the Propellor and I hope it isn't something in the lower unit.
Any advice?
Any advice?
