Pull cord worn't retract.
Scottina
I recently rebuilt the carbs on my 50 hp mercury thunderbolt. Now my pull cord won't retract. Is there an easy fix for this, or am I going to have to take the whole thing apart?
Thanks,
Scott:eek:
Faztbullet
Re: Pull cord worn't retract.
If the grease is thick it can cause this..
Mi duckdown
Should be able to spray it down with brake or parts cleaner to remove the crud.
Must be a Big guy to pull start a 50.
Scottina
Not that bad to start. Not a real big guy. What should I spray down? Do I need to take anything apart?
Mi duckdown
All the moving parts. just take the hood/cover off and see what happening.
What year/ serial number, do you have?
Scottina
It is a 70ish 50hp thunderbolt mercury. Not sure about the serial number. Is there anything I can do forst before I go messing with the spring and taking it apart. Should I spray the parts with engine cleaner? Sorry for the dumb questions. Not a mechanic.
