DBreskin
- Oct 20, 2009
- 799
I've had the boat in my signature for two seasons. I replaced the bellows in 2010. It used to run bone dry; not a drop of water in the bilge after a day out. This season I noticed a pint or two of water collecting in the bilge and wondered how it got in. Yesterday it got much worse; the bilge started filling enough to trigger the bilge pump about every 5 minutes.
I looked (as best I could) at the transom assembly from inside the boat and could see water running in. I couldn't tell where it was coming from exactly. The water was coming in while the engine was off. The two likely candidates are a faulty bellows or a failed transom housing seal.
Can anyone suggest any other source, and a way to determine where the problem lies? I can try filling up the bilge while the boat is on the trailer and see where it comes out, but then I can only fill it as high as the bottom of the starter.
FYI, the lower unit was rebuilt in fall 2010. Everything except the drive internals and the bellows are original to the boat.
